Insulation, Simple Questio - If You Know The Answer - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-02-2007, 10:33 AM   #1
mt232's Avatar
Insulation, simple questio - if you know the answer
Does the electrical wiring go behind theinsulation (between the insulation and exterior walls), or infront and closer to the interior walls?
mt232 is offline   Reply With Quote
Old 07-02-2007, 11:18 AM   #2
RippySkippy's Avatar
When you run a wire horizontally in an exterior wall, split the insulation and run the wire in the middle. Make sure you cut in around the boxes i.e. don't cram it in. Also make sure you have insulation between the boxes and the sheathing, not too much but fill in the external spaces.
You can use expanding foam around the boxes to seal them up from infiltration, BUT if you have to work on the box in the future, it will be a PITA.
RippySkippy is offline   Reply With Quote
Old 07-02-2007, 11:25 AM   #3
mt232's Avatar
great, clear answer, thanks!
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Rigid insulation question Endeavor General DIY Discussions 2 07-17-2007 10:27 AM
dormer window insulation wlm-21 Building & Construction 2 02-13-2007 04:04 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
Insulation material reusable? KUIPORNG General DIY Discussions 4 06-19-2006 02:38 PM
