Insulation Of Rim Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-03-2011, 10:09 PM   #1
insulation of rim joist
I have pink insulation in the joist already can i just foam over that
sherryne is offline   Reply With Quote
Old 01-04-2011, 01:12 PM   #2
Rewards Points: 590
Seems like the weight of the foam would cause the insulation to fall apart unless you used a wasteful amount. Why not pull it out, and use rigid foam board instead? If you cut accurately, you could just caulk the edges and not even need any spray foam.
operagost is offline   Reply With Quote
Attic Insulation paige2 General DIY Discussions 21 03-16-2011 11:35 AM
Floor joist insulation Arky217 Building & Construction 0 12-29-2010 12:56 PM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 11:50 AM
Rim Joist Insulation ja191992stg Building & Construction 53 03-22-2010 09:41 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
