Insulation - R-13 - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-18-2008, 11:10 AM   #1
Insulation - R-13
Putting insulation in the walls in my basement - is an R-13 Faced rolled Insulation sufficient for the walls?
SnowUtopia is offline   Reply With Quote
Old 06-19-2008, 06:15 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
I'm assuming your framing the basement with 2x4's R-13 would be the right choice. What I would recommend is to make sure you keep your framing off the foundation wall at least 2". Reason 1. you don't want the insulation to come in contact with the exterior wall. In case of leaks. I have seen a few basements where the fiberglass made contact with the foundation and black mold was formed on the back half the insulation.
If you can paint the interior of the walls with some type of sealer. Like dry lock. Years ago I can remember using tar to seal the walls, the smell stayed in the house for weeks, when my wife put the close in the clothes dryer the would come out smelling like burnt asphalt. but it worked and still, 27yrs later no leaks. good luck BOB
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 02:13 AM
Cantilevered floor insulation rickswa Building & Construction 5 01-02-2008 12:08 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
