Insulation Questions For New Detached Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-01-2009, 06:40 AM   #1
Rewards Points: 12
Insulation questions for new detached garage
Hello:
I'm having a detached garage built. I'll be doing the insulation work after it's built and I want to make sure that the prep work is done properly.
The garage has a small room above with knee walls and no attic. I'd like to have a ridge vent and soffits installed, however, soffits seem to be for homes with attics that allow for air to move thru the soffit and out the ridge vent. I'll be attaching the insulation directly to the the roof trusses, effectively blocking the flow of air to the ridge vent.
Eve vents and a powered attic vent don't seem to be the solution either.
How do people insulate and vent a room over a garage?
Thanks,
Mike
mpt1123 is offline   Reply With Quote
Old 03-01-2009, 06:56 AM   #2
Insulation should never be installed directly to (under) roof sheathing. It causes condensation that will rot out the sheathing. There are foam baffles that you fasten to the sheathing that allows air flow, with insulation installed over them.
Old 03-01-2009, 08:18 AM   #3
Rewards Points: 12
Bill:
Thanks for the help. I think I get it now. Install something like Raft-R-Mate from Corning the entire length of the rafter cavity, then insulate on top of that. This would provide a channel for air to circulate between the soffit and the ridge vent. Nice.
Thanks again,
Mike
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 01:46 PM
Questions on Building apartment On top of existing detached garage nsxman2001 Building & Construction 4 12-16-2008 04:36 PM
New detached garage, wiring, questions gp_wa Electrical 9 12-04-2008 03:10 PM
Grounding for detached all-metal garage geeswanie Electrical 3 07-03-2008 07:31 AM
Detached Garage Insulation Unregistered Building & Construction 2 02-28-2004 03:31 PM
