#1 |
Insulation questions
I have gutted an area for a new bathroom in an old wood house built in 1863. The only thing between the exterior and the inside of the bath is thin clap board siding. I will be putting unfaced insulation up and covering it with plastic facing the interior of the bath. The wind can blow in between the clap board so I want to cover them with tar paper first as protection. Is tar paper considered a vapor barrier? I know you are not supposed to have facing on both sides of insulation.
Also, how does one secure unfaced insulation to walls without tabs? Thanks in advance to all who help. |
#2 |
Moderator
Plastic and tar paper are vapor retarders with plastic being air-impermeable- a true vapor barrier. Plastic inside only in cold and very cold areas: http://www.buildingscience.com/docum...gs?full_view=1
http://www.buildingscience.com/docum...gs?full_view=1 Foam board would help unless cost is an issue. Tar paper and asphalt paper: http://www.fortifiber.com/pdf/fortif...sk_vs_felt.pdf Unfaced is factory cut larger than cavity width to self support. http://www.buildingscience.com/docum...archterm=insul Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| Display Modes | |
| Basement insulation / vapor barrier questions | deepstuff | Building & Construction | 16 | 02-09-2012 10:11 AM |
| Some questions about attic insulation and improving it. | Mister Sonny | HVAC | 5 | 06-29-2010 11:00 AM |
| Questions on basement insulation | jedispork | Building & Construction | 0 | 06-27-2010 10:53 PM |
| Basement Insulation Questions? | BobR | General Discussion | 1 | 09-30-2008 10:25 PM |
| Installing new insulation in my basement and removing the old moldy insulation. | Fixitgeorge | Remodeling | 3 | 10-17-2006 09:33 PM |
