Insulation Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-31-2010, 09:49 AM   #1
jpc
jc
Rewards Points: 162
Send a message via Yahoo to jpc
Thumbs up
insulation question
hello everyone, forgive me if this has been covered previously, and thank you in advance for any and all help.My question is, The house i bought has a finished room above the garage, kneewalls on both long walls, being the biggest room in the house, naturally my bedroom, problem is its very tempermental with the seasons,I have an access door on each wall, inside the eaves, the kneewall is insulated but the plywood sheeting for the roof is not, Is that normal? and as i have a pile of 3/4 inch think sheets of pink board, i think i said it has an r30 value, was wondering if i could sheet the bottom of the rafters inside the kneewall with this? if there is any information i left out let me know ,and again thank you
jpc is offline   Reply With Quote
Old 12-31-2010, 11:51 AM   #2
Rewards Points: 1,092
insulate the knee wall more, using the rigid foam if you can; seal the joints w/ foam and tape. leave the roof sheathing alone. you want your insulation against the exterior wall of your living space. you can spray foam the sheathing, but that opens a can of worms. do a search here; lots of threads on this.
The Following User Says Thank You to jklingel For This Useful Post:
jpc (01-08-2011)
Old 12-31-2010, 07:29 PM   #3
Registered User
Rewards Points: 5,516
R-30 for 3/4" may be a little high; http://www.energysavers.gov/your_hom.../mytopic=11620
Is the sloped ceiling vented from below (knee wall) attic (4.2.1.2); http://building.dow.com/ee/pdf/ESR-2142.pdf
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
jpc (01-08-2011)
Old 01-05-2011, 12:29 PM   #4
jpc
jc
Rewards Points: 162
hey those links were very helpfull, I dont know what i was looking at where i read r 30, thanks again
Garage insulation question trojanman1 Building & Construction 7 09-16-2009 02:51 PM
Question about Insulation russstar Roofing/Siding 13 08-21-2009 10:10 AM
rafter insulation question Jeremy Hillary Boob, PhD Building & Construction 7 08-02-2009 08:19 AM
Insulation Question skavang13 Building & Construction 3 11-16-2008 05:08 PM
Insulation question..... v12357 Building & Construction 5 09-14-2008 08:04 PM
