Insulation Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-10-2010, 03:51 PM   #1
Insulation question
Here's the deal, I am redoing part of my bathroom including the outside wall, I need 4 pieces of insulation for that 2X4 framed outside wall.
I have a bunch of left over R-19 6" thick insulation.
My question is if it's ok to shove the R-19 into that wall? I know that smooshing down fiberglass insulation will hurt it's R-value, but will it lower the R-19 to less than R-11?
Would it really be worth it to buy an entire pack of R-11 over just using the R-19 that I currently have?
Lockeset is offline   Reply With Quote
Old 11-10-2010, 04:06 PM   #2
r-13 is the standard for 2x4, the older insulation that was r11 isn't up to the same standard as what's sold today. if you really wanted to a mini roll of r13 is $8 at home depot. me? i'd shove your r19 in there. by compressing it you will loose some of the r value but i'd guess you would fall somewhere in the r13-15 range by doing so.
racebum is offline   Reply With Quote
Old 11-10-2010, 05:14 PM   #3
Registered User
Rewards Points: 526
You nailed it at R-13: http://saveenergy.owenscorning.com/2...nd_your_2.html
Gary
Old 11-10-2010, 05:16 PM   #4
I've used plenty of R-11 today, you can buy it from any of the manufacturers, it's unfaced batts. The reason I want to use unfaced batts is because I will be using plastic behind the cement board in the shower and I don't want to have 2 vapor barriers. I see a lot of R-11 used in commercial jobsites in the 3 5/8" interior walls.
Good to hear, thanks
Old 11-10-2010, 05:16 PM   #5
Originally Posted by GBR in WA View Post
Great, thanks!
Garage insulation question trojanman1 Building & Construction 7 09-16-2009 02:51 PM
Question about Insulation russstar Roofing/Siding 13 08-21-2009 10:10 AM
rafter insulation question Jeremy Hillary Boob, PhD Building & Construction 7 08-02-2009 08:19 AM
Insulation Question skavang13 Building & Construction 3 11-16-2008 05:08 PM
Insulation question..... v12357 Building & Construction 5 09-14-2008 08:04 PM
