Insulation Outside The Roof? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-02-2007, 10:00 AM   #1
Insulation Outside the roof?
On the dormers I'm building, I can't loose much more head room, so I'm stuck with 6" insulation (cause of the air vent and demensional size of the 2 X 8 rafters) unless I go outside the roof.
Can I put insulation sheeting between the rafters and plywood sheeting?
Other solution?
fauer is offline   Reply With Quote
Old 10-02-2007, 08:47 PM   #2
kemerick's Avatar
Rewards Points: 87
I can't see how insulation on the inside of the roof would hurt, except for your wallet. The more insulation the better...
My constant project is my home, my play time is usually spent on my CNC router.
kemerick is offline   Reply With Quote
Old 10-02-2007, 09:19 PM   #3
DeeTee's Avatar
Cool
Of Course
Yes you can, if you mean putting the insulation above the trusses/rafters. One example is SIPs (a piece of insulating foam sandwiched between two pieces of OSB) that are often used between trusses and the finished roof in order to provide ceiling insulation for cathedral ceilings, for example.
___________________________________________
Precision is always relative to the surrounding degree of perfection.
News Views Tips Commentary Downloads at the Construction Informer
DeeTee is offline   Reply With Quote
Old 10-02-2007, 09:48 PM   #4
Your dormer has a window in it right? Letting in sunlight. 6"s will be plenty for that small of span, you already have the venting in place.
The costs vs. savings in very marginal in this application.
97catintenn is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 09:44 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 07:28 AM
Flat Roof Suggestion gladiator Roofing/Siding 3 09-14-2005 03:31 PM
