#1 |
Insulation older house
Our home was built in the early 60's with 2 x 4 and stucco. When the outside drops below minus 20 C the walls in the closets, kitchen cupboards and electrical plugs freeze up. I want to remove the stucco, then add Thermax CI external insulation and finish it of with NEXSTONE panels. Will I need to ad a vapour barrier between the wood and the "thermax" and will that give us enough insulation?
#2 |
Moderator
Welcome to the forum! Where is the house located?
Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| Display Modes | |
| Buying an older house | jayinwww | Project Showcase | 3 | 06-10-2011 06:43 PM |
| insulation and sealing questions stone/brick house | mtk | Building & Construction | 9 | 01-28-2011 09:30 AM |
| Rafter Vents and Insulation | nofx1981 | Roofing/Siding | 15 | 03-10-2010 09:14 PM |
| grounding of main panel and sub panel in older house | linkysys | Electrical | 2 | 10-01-2009 05:34 PM |
| 1940s house in mid TN, block walls, no insulation | kscudebec | Building & Construction | 2 | 01-15-2009 05:22 PM |
