Insulation And Nesting Problems - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-27-2008, 10:24 AM   #1
insulation and nesting problems
Newbie user to the listserve.
I am renovation an old 1905 cabin without utilities. Among other things, adding wall insulation, probably batts. We do have a rodent problem with field mice when we are not there for longer periods. Anyone know is there a type that will reduce chances of nesting or a "nest unfriendly" material?
Could you indicate if you have products that you would suggest based on experience and knowledge, and any tricks to using them?
achess is offline   Reply With Quote
Old 07-31-2008, 05:03 PM   #2
the Musigician
DangerMouse's Avatar
blown insulation can be made bug and rodent repellent
DM
Old 07-31-2008, 10:12 PM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
DM
Correct and it also can be fire retarted. BOB
Old 08-05-2008, 09:02 PM   #4
thanks
does this involve an additive to the insulation or a brand/type?
Old 08-06-2008, 06:30 AM   #5
the Musigician
additive to the insulation, ask at local store for rodent/bug/fire repellent cellulose. brand name should not matter. they should steer you to the right stuff.
DM
Old 08-10-2008, 03:28 PM   #6
experience is a wonderful thing
thanks
I will check it out
