-   -   Insulation inside air returns (http://www.diychatroom.com/f19/insulation-inside-air-returns-166495/)
Mijotter 12-15-2012 02:45 AM
I'm replacing my old sheet metal returns in the ceiling with Thermopan duct board. My question is, can I place xps rigid foam board in the rim joists inside the return before putting the new duct boards up? I would seal them with Great Stuff or is that not advisable.
md2lgyk 12-15-2012 08:29 AM
Why would you want to insulate a return duct?? I don't see why you couldn't put in some XPS but don't see the point of doing so.
joecaption 12-15-2012 09:27 AM
Only supplys need to be insulated.
Mijotter 12-15-2012 02:29 PM
1 Attachment(s)
not insulate the duct themselves. just the rim joist that the plenum buts up to. This is a basement ceiling btw. I have all the other open rim joists properly insulated and was just wondering if I should do the same that the plenums butt up against in the ceiling as they follow the ceiling joist.
Mijotter 12-15-2012 04:22 PM
Anyone? Would like to get this started today.
HVACTECH96 12-15-2012 05:35 PM
Looks like panning on bottom of joist.If this panning is going all the way to the outside bond, then chances are there are openings at the exterior walls for R/A going to upper floors.So trying to put insulation in the joist space around the bond probably wont be possible without covering cutouts.
Mijotter 12-15-2012 05:38 PM
Correct but there is about 3 inches of space between the cutout and the outside wall where 2"xps could feasibly go. I just need to know if it will helop with insulation at all and that kind of insulation will be ok in a return(health reasons
md2lgyk 12-15-2012 06:01 PM
I wouldn't do it. No reasonable return (pardon the pun) to justify the expense and effort.
HVACTECH96 12-15-2012 06:01 PM
You planning on replacing metal panning with duct board or using pieces of duct board to insulate .
Mijotter 12-15-2012 06:02 PM
replacing the sheet metal with Thermopan ductboard.
HVACTECH96 12-15-2012 06:06 PM
If it were me I would use pieces to insulate the bond and leave the metal up.Or buy couple cans of great stuff and foam the space for a better air seal.
Mijotter 12-15-2012 06:17 PM
Why is that? The reason i'm doing this is because it's old, filthy, and I'm sound proofing the basement. Will xps in that area hurt or not?
