Insulation Help. - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-08-2011, 08:34 PM   #16
Registered User
Rewards Points: 4,912
OSB-SPF-NO,NO; http://www.buildingscience.com/docum...d%20in%20walls
Gary
Old 01-09-2011, 12:24 AM   #17
IHICH2011's Avatar
Originally Posted by neva_2l82_learn View Post
I'm hoping this will be the last home we buy, so we plan to live in it for a long time. We got a quote for spray foam today. It came in at $7,200.
As mentioned above..you can get very technical with insulation and the many types available. Some can be easy fixes as I mentioned or with the new PIR can get a little spendy..Your spray foam cost is within the norm.
With spray foam you will be happy in the end knowing your home is well insulated. If you go through with this..make sure all wiring, plumbing and all wall penatrations are complete before insulating. Your contractor will double check this before he does any work.
What ever you decide...your well insulated home will have a plus if you ever decide to sell.
IHICH2011 - I Hope I helped
IHICH2011 is offline   Reply With Quote
Tags
furring , insulation
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 03:33 PM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 11:50 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
