Insulation Foam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-20-2013, 04:17 PM   #1
Insulation foam
I built a vaulted cieling n am getting spray foam. Should I get open cell or closed cell foam. What's the difference n which should I put on my vaulted ceiling. My rafters r only 2 by 6s. That's y I'm spray foaming them. Anyone know the difference n would either help or hurt
ecocco1469 is offline   Reply With Quote
Old 03-20-2013, 04:21 PM   #2
Rewards Points: 14,312
Now go back and add your location to your profile for an ansewer. Just go to Quick links to edit.
You could be from anyplace on the planet for all we know.
Old 03-20-2013, 05:43 PM   #3
Long Island
Old 03-20-2013, 05:49 PM   #4
Rewards Points: 626
Vaulted ceiling must be at a R-38 how many inches of foam are you spraying in? and are you leaving enough of a gap to have air move so you don't prematurely kill your roof? the roof sheathing needs to breath. or your shingles will curl and cause you to replace your roof way sooner then needed. I hate vaulted ceilings just for that cause. you have to put air channel baffles all the way along the truss and sheathing then either foam spray $$$$ there or HD FG batts. either way pain in the butt to get to R-38
Nailbags is offline   Reply With Quote
Old 03-20-2013, 08:22 PM   #5
747
registered
747's Avatar
Rewards Points: 534
Close cell is more expensive because it has more r value then open. Actually there is a little more to it then this. But its the bottom line.
747 is offline   Reply With Quote
Old 03-20-2013, 08:40 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,358
locally open cell foam runs $3.75 sq ft roughly, closed cell is $4.75,
woodworkbykirk is online now   Reply With Quote
Old 03-21-2013, 07:44 AM   #7
Rewards Points: 3,130
2x6 rafters seem pretty small for an area that gets lots of snow. I have a 12/12 vaulted ceiling in my log house (Eastern WV) and the rafters are 2x12s. A real pain to put up (long and heavy), but during Snowmageddon a few years ago we had 4 feet of snow on the roof for several days without a problem. And, as Nailbags said, it's going to be tough for you to get R-38 insulation.
Installing XPS foam panels where existing pink bat insulation. Siubeer Insulation 15 06-28-2012 10:27 AM
Spray foam insulation odor Ranger1227 Insulation 6 02-14-2012 11:53 AM
Hybrid Spray/Rigid Foam Insulation yaemish Insulation 4 01-20-2012 11:55 PM
Canned Foam Insulation WindingRoad Building & Construction 5 01-02-2011 09:08 AM
Floor insulation, cellulose vs hard foam Arky217 Flooring 0 12-23-2010 10:44 PM
