Old 03-17-2007, 02:51 PM   #1
Insulation - Faced or Unfaced?
Hi all - new user with a question about interior insulation.
I am Owner-Building a house located in the Sierra at 5000 feet elevation. Temps range from lows in the 20s to high in the 80s with low humidity levels year round.
The house is 2x6 stick framed with OSB exterior sheathing covered with Tyvek housewrap topped with furring strips supporting T&G cedar siding.
I am ready to install wall insulation and my question is this - do I use faced or unfaced batt insulation for the walls?
Reason I ask is that I am concerned about creating a moisture pocket in the exterior walls by having a double vapor barrier.
Meaning that the Tyvek on the exterior acts as a VB - would faced batts on the interior side of the space act as a second VB and possibly trap moisture within the wall?
Or do I want faced batts to seal interior moisture away from the wall cavity?
Thanks.
Rick
Ricky D is offline   Reply With Quote
Old 03-17-2007, 03:00 PM   #2
Power Gen/RS Engineer
Tyvek acts as an air barrier (and a barrier to moisture infiltration due to driven rain). It is moisture permeable however and will allow vapor movement out of the wall cavity.
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves,"You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." - George Carlin
BigJimmy is offline   Reply With Quote
Old 03-17-2007, 03:24 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
"... It 'acts' like a vapor barrier..."
- BigJimmy is right about this. (It works like Goretex clothing)....
http://en.wikipedia.org/wiki/Tyvek
From the link above:
"Water vapor can pass through Tyvek, but not liquid water"
To answer your question...use faced insulation for the walls...Face the paper towards the warm areas.
- Build Well -
Old 03-17-2007, 03:26 PM   #4
DUH - you're right - Tyvek does allow vapor to migrate outward. So that would mean that faced batts would be fine for the exterior wall cavities.
Makes sense.
Thanks.
Old 03-17-2007, 06:29 PM   #5
Originally Posted by Ricky D View Post
...So that would mean that faced batts would be fine for the exterior wall cavities.
Unless I'm mistaken, it's the only application where it makes sense. On the other hand, I've seen people install unfaced batts in exterior cavities with 4-6mil poly laid over the studs to act as a vapor barrier. Whichever, the goal is to have the VB on the warm side to prevent the diffusion of moisture into the wall cavity where it can cause mold, rot, etc.
Good luck and take care!
Jimmy
Old 03-17-2007, 09:47 PM   #6
General Contractor
joasis's Avatar
And you could find a contractor that blows cellulose...wet blown in the walls or glue set. Perfect fill and no barrier needed. In my area, we charge .65 a sq/ft for 2X6 walls..and the R value is better then batts....green material also....
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Rigid insulation question Endeavor General Discussion 2 07-17-2007 11:27 AM
dormer window insulation wlm-21 Building & Construction 2 02-13-2007 05:04 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
faced or unfaced insulation wiggs Building & Construction 5 04-19-2006 06:50 AM
