Insulation-exposed Pipes - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-02-2009, 06:00 PM   #1
Unhappy
insulation-exposed pipes
we have bought a modular house built in 1970 on poles. The house is 2ft above the ground. The water/air conditioning/heat pipes are under the house with some insulation around them, but otherwise exposed. We think that we lose a lot of heat How can we insulate better? Should we heat under the house ? How? should we build a skirt around the house? What materials are best?
Thanks,
Rossi is offline   Reply With Quote
Old 03-02-2009, 08:51 PM   #2
you don't want to heat under the house unless its well protected, even then its probably a waste of heat. i would try to enclose the pipes inside what they call the 'building envelope'. insulation, then pipes then house. insulation only keeps heat in.....it does not create heat. so if you keep the pipes inside the heated part of the house you will be better off. no insulation between the heated part of the house and the pipes.
nickct is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Burying exposed copper pipes ryan_s HVAC 1 11-20-2008 08:20 PM
Rigid Insulation Exposed timchi29 Remodeling 3 11-07-2008 01:52 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
