Old 03-12-2007, 03:51 PM   #1
mt232's Avatar
insulation or electric first?
I'm having an addition framed for me, then i'm doing electrical and insulation, but which should be done first?
mt232 is offline   Reply With Quote
Old 03-12-2007, 04:05 PM   #2
Definately do the electrical first. And for the love of God, do not let beer geek know if your outlets are more than 12' apart.
steel is offline   Reply With Quote
Old 03-12-2007, 05:51 PM   #3
yummy mummy's Avatar
I second that one, don't tell beer geek,
Love your sense of humour steel.
yummy mummy is offline   Reply With Quote
Old 03-12-2007, 08:05 PM   #4
They're right, don't tell me that you're too stupid to follow code. I'm sure the private message told you to just make things up as you go along.
It takes less time to do a thing right than it does to explain why you did it wrong.
-Henry Wadsworth Longfellow
beer_geek is offline   Reply With Quote
Old 03-12-2007, 08:07 PM   #5
And to answer the question, pull the wire first. It's easier to separate the insulation than it is to move the wire around it.
Old 03-12-2007, 09:09 PM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You should always install your wiring and plumbing before insulation.
Insulation will be in the way. Not to mention that you will be 'out of sequence' for your inspections.
What I mean is that, you need to have your framing inspection before your insulation can be installed and inspected.
....and, you need to have your electrical inspected and ok'd, in order to have your framing inspection.
The reason for this (framing inpsection coming after electrical Insp.) is to make sure that plumbers and electricians have not drilled thru any structural members in such a way as to compromise their ability to support weight loads. (It has happened)
The framing inspection then comes before the insulation inspection...so that the inspector can actually see the framing (which would be difficult to see and inspect, if there were insulation up)
- Build Well -
Old 03-15-2007, 01:18 PM   #7
mt232's Avatar
Thanks for the inf, and nope, I wouldn't think of disregarding code......
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
dormer window insulation wlm-21 Building & Construction 2 02-13-2007 05:04 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
Insulation material reusable? KUIPORNG General Discussion 4 06-19-2006 03:38 PM
