Insulation Comparison ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-08-2009, 01:23 PM   #1
I'm evaluating quotes to have insulation blown into all the existing exterior walls of my house and need an objective comparison of the three major infill types of insulation (fiberglass, cellulose & foam) and am having a dickens of a time finding something. The vast majority of charts I've found are created by the various companies and have obvious biases towards one product or the other. The cost difference between loose fill and foam is also pretty substantial (about 50%) so I want to make sure that my money will be spent in the most efficient manner. I am currently leaning towards the blow in fiberglass but can be swayed with good data to either direction.
Thanks!
:beer:
cellophane is offline   Reply With Quote
Old 12-08-2009, 04:03 PM   #2
Remodeling Contractor
This really depends on the type of wall cavity you have now and what insulation is already in there. Cellulose will settle better into the area than fiber glass. Foam is better insulation but difficult to fill existing exterior voids.
Old 12-08-2009, 04:07 PM   #3
walls are 2x4 framing with plaster & lathe on the interior, wood siding covered by aluminum siding on the exterior. house is roughly 90 years old. there is no insulation currently in the wall cavities.
Old 12-08-2009, 04:49 PM   #4
Civil Engineer
Rewards Points: 4,952
I had a similar problem deciding what type of insulation to add to my 1959 house with 2x4 framing and no insulation. After considerable research, I decided to go with blown in cellulose insulation. Foam had a number of issues, including high cost and the potential to overexpand. I eliminated fiberglass because I concluded that cellulose was more likely to fill the cavity completely.
I had cellulose blown in by a contractor. It went quite well, my 1800 square foot, two story house was done in two days. Last year we were unable to get the temperature in the house over 62 degrees in the winter with just the wood stove, this year we routinely achieve 68 degrees, occasionally 70 degrees, with just the wood stove. I also insulated the basement rim joists (myself) using extruded styrofoam blocks, so part of the improvement is due to that project, but still I have been happy with the cellulose result. Of course, fiberglass may have achieved similar results, can't say.
Old 12-08-2009, 05:56 PM   #5
Rewards Points: 582
One of the most popular forms of Cavity wall insulation here in recent years is polystyrene beads pumped into the cavity and resin bonded.
Mineral fibres have in some cases compressed slightly over the years and left a cold spot at the top of the walls causing condensation.
The beads have also performed well in filling the cavity without any voids.
stuart45 is offline   Reply With Quote
Old 12-08-2009, 06:08 PM   #6
Registered User
Rewards Points: 526
"but can be swayed with good data to either direction. " Cellulose over glass: more R: http://hes.lbl.gov/hes/makingithappe...omparison.html ----------------------------- fire safer: http://www.cellulose.org/userdocs/Te...ectiveness.pdf ---------------- better air sealer: http://www.homeenergy.org/archive/he...92/920510.html --------------------- in attic: http://michaelbluejay.com/electricity/insulation.html
Be safe, Gary
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 09:57 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
