Insulation With Black On Faced Side? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-01-2010, 03:06 PM   #1
Insulation with black on faced side?
I recently had my attic insulated with R38c, but i noticed that a lot of batts were almost like burned on the face side? Has anybody seen this before? I have attached a picture. They were like that when we bought them in the package? there were only a few of them. Is that mold?
THanks
ddave23 is offline   Reply With Quote
Old 01-01-2010, 03:17 PM   #2
ccarlisle's Avatar
Doubt that's mould...bitumen-based vapour retarder material showing through the kraft more like it...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 01-01-2010, 04:07 PM   #3
Registered User
Rewards Points: 4,912
I agree with ccarlisle. I would be more concerned to block the attic space air at the rafter bays over and under the knee walls. And where the rafters step in elevation: http://www.simplesavings.coop/simple...ee%20walls.pdf
And the air space gap between the insulation face paper/drywall back, and inside stapling: http://oikos.com/library/insulating_...lls/index.html
Did you install baffles over the all the cathedral ceilings? I don’t see one in the closest bay of near rafters in attic.(Could be my eyes,LOL) You left the paper on the batts in the attic (fire code violation) but didn’t run the ceiling insulation all the way down? Yet you insulated the knee walls. Is this a conditioned attic or vented? http://www.southface.org/web/resourc...lings_4pdf.pdf
Be safe, Gary
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
rafter insulation question Jeremy Hillary Boob, PhD Building & Construction 7 08-02-2009 09:19 AM
Radiant barrier with faced insulation? luci468 Building & Construction 1 07-18-2009 04:49 PM
Kraft faced batt insulation Charles_cz Building & Construction 1 06-09-2009 10:29 AM
can't get new light fixture to work carolcwilson Electrical 24 08-12-2008 01:52 PM
