Insulation -- Best Place To Start In Old House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-17-2009, 08:24 PM   #1
JPM
Bill Traver
Rewards Points: 93
Insulation -- best place to start in old house
I own a very old house "down the shore" in NJ. There is limited to no insulation in either the walls or the ceiling. Which do I do first? The roof is flat with no "attic". The walls have been updated from plaster to sheetrock. Not sure what I can do to the ceilings. Ideas?
I believe that I can attempt to blow in insulation into the walls.....that is a second question,,,,can anyone comment on how hard that it is do and how does it compare in cost to standard insulation?
Thanks,
Cold in NJ
JPM is offline   Reply With Quote
Old 02-17-2009, 10:03 PM   #2
Heat rises, so if you insulate the walls heat will still rise
I'd do the ceiling 1st
Basement?
Crawl space?
Do you know the ceiling joist size ?
Old 02-18-2009, 10:18 AM   #3
Can you expand on the design of the roof/ceiling? Is it flat, but constructed of like 2x8 or 2x10's with drywall for the ceiling? If so, you could start by blowing in insulation into that cavity. I agree with Dave, do whatever you can to the ceiling first for the biggest impact.
From there you could blow insulation into the walls fairly easy.
Ininkus is offline   Reply With Quote
Old 02-18-2009, 11:14 AM   #4
JPM
Bill Traver
Rewards Points: 93
follow-up
OK...I like that idea as the ceilings are drywalled. I have not blown in insulation so some guidance on that would be appreciated. I believe I'd cut a small hole, feed the hose, then start. How far should I expect the blower to fill?
From a cost perspective, how does the blow-in insulation compare to the rolls/sheets? I am trying to figure out the budget side of getting this done as well.
Thanks,
BT
Old 02-18-2009, 07:23 PM   #5
Dont expect much with just insullating the ceiling. I have a building that was built in the late 1800's and tried the ceiling first, maybe I picked up 2-3 degrees. Unfortunatly the walls stay cold and w/o insullation in them the heater cant warm the walls and you. I need to do the same thing as you and have analyzied it to nauseaum. Cant deal with $ 500 a month in gas bills so Blown insulation is the leaset expensive way to do it.
AJ&J is offline   Reply With Quote
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
Old House Rewire finnimus Electrical 15 05-13-2011 11:39 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 06:59 PM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 07:01 PM
1940s house in mid TN, block walls, no insulation kscudebec Building & Construction 2 01-15-2009 05:22 PM
