Insulation Behind Tub Area Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-14-2009, 08:44 AM   #1
Rewards Points: 135
So I have the tile all demo'ed, studs exposed. The fiberglass insulation is not in bad shape, but its texture is a bit "mushy" when you squeeze it. Easy enough to rip out and replace with new. Possible it may have been exposed to moisture. So, should I replace with new fiberglass insulation or use some other material, perhaps foam board? Ideally, something that would prevent future mold or mildew growth because of exposure to high humidity. I will use cement board and thin set mortar in front of it, but I think it may still be exposed to moisture.
smata67 is offline   Reply With Quote
Old 07-14-2009, 10:45 PM   #2
TooledUp
What about that foam insulation. I do not think that stuff absorbs water.
TooledUp is offline   Reply With Quote
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
super insulation retrofit with rigid insulation hostaking Building & Construction 5 01-07-2009 10:23 AM
Cantilevered floor insulation rickswa Building & Construction 5 01-02-2008 12:08 AM
Insulating walls between attic & heated area Hobiedog Remodeling 4 11-08-2007 03:56 PM
