Insulation For Basement Ceiling Under Hardwood Floors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-23-2010, 02:01 PM   #1
Insulation for Basement Ceiling under hardwood floors
Just getting to the point of insulating our interior basement walls and ceiling. WE have wood floors all throughout our upstairs and would like to add insulation into the basement ceiling as a way of cutting down some of the noise transfer between the two floors. What R-value would give me the most bang for my buck? Thanks!
anygren is offline   Reply With Quote
Old 08-24-2010, 11:57 PM   #2
Rewards Points: 1,092
This idea of insulation being used for sound proofing was discussed at length here (or on the garagejournal.com site). Do a search, as I don't think there was a hard answer. Obviously, it helps some, and the thicker the better, but there are apparently better options. I know that if I remove a 2'x4' tile (that structurally useless ceiling tile everyone uses) in my basement ceiling, the noise level goes up dramatically (ie, they deaden the sound from above pretty well). BTW: When I hung the wire to support the metal framing that holds the 2'x4' tiles, I put rubber between the wire and floor joist to minimize noise transfers. Personally, I don't think fiberglass insulation is dense enough to do stink, but maybe cellulose batts or mineral (rock) wool will help. Mineral wool CLAIMS to be better at noise deadening, but I know of no studies that prove that; never researched it. Try to find the previous discussion; sheet rock may be better than most insulation, if I recall.
where to get 1/4" thick hardwood floors? dozu Flooring 3 04-30-2011 05:17 AM
New buckled hardwood floors Angela3511 Flooring 12 07-16-2009 07:58 PM
Tile over Oak Hardwood floors (unfinished) irishgem@ymail. Flooring 3 07-13-2009 09:07 AM
R30 ceiling insulation with 2x4 roof trusses I_think_I_conduit Building & Construction 4 04-04-2008 03:43 PM
polyurethane coat for hardwood floors. christy123 Flooring 2 12-10-2006 10:20 PM
