Insulation Basement - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-07-2009, 12:08 PM   #16
Remodeling Contractor
Originally Posted by GBAR in WA View Post
Bob, you may want to clarify this: "Use foundation sill insulation under the sole plate. This will allow air to flow into and out of the wall space you need to provide."
Sill sealers are to seal the air and moisture out from the living space. They don't allow air through them. Be safe, GBR
You are 100% right, not what I was trying to say. Foam in this situation is to provide a capillary break just like the foam board on the concrete wall.
I also posted this as who to handle a pressure treated sole plate on this other post.
Material for capillary break under PT Framing in basement
Notice the MOD's reply and he is our inspector.
Thanks for reading my posts better than I wrote them. All the help I can get is welcome.
basement insulation and vapour barrier coolnes Remodeling 11 02-01-2009 09:56 AM
basement insulation question benp Building & Construction 2 03-24-2008 11:46 AM
adding Insulation to finished basement Mr Chips Remodeling 2 03-23-2008 11:16 AM
Basement "Edge" insulation Wil Building & Construction 3 04-05-2007 11:04 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
