Insulation For Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-03-2012, 12:02 PM   #1
insulation for basement
Hi i am changing insolation in basement . The question is should i put back the fiberglass or i can put a ridgid insolation. Thanks in advance
leonid is offline   Reply With Quote
Old 10-03-2012, 12:04 PM   #2
Rewards Points: 2,212
Styrofoam.
http://www.buildingscience.com/docum...lation-systems
mae-ling is offline   Reply With Quote
Old 10-03-2012, 12:07 PM   #3
Thank you and should it be a vapor barrier?
Old 10-03-2012, 12:16 PM   #4
Read the eniter link. No Vapor Barrier.
The Following User Says Thank You to mae-ling For This Useful Post:
leonid (10-03-2012)
Old 10-03-2012, 12:25 PM   #5
Can i ask u a question about flooring? Basement also
Old 10-03-2012, 12:35 PM   #6
Sure ask away, If i can't answer others probably can
Old 10-03-2012, 12:40 PM   #7
I want to put laminate floors . I removed carper and undern it was parquet . The parquet floor in directly on concreet . The question is can i put laminate on top of the parquet or its beter to put subfloor like dricore ?
Old 10-03-2012, 12:43 PM   #8
The other possibility is to put 2x4 on concreet and then plywood like 3/4 and then laminate.
Old 10-03-2012, 01:25 PM   #9
I am not sure about the floor, thinking dricore is not a good idea.
Hopefully GBW will come along, listen to him he has probably forgot more about this then I know.
Old 10-22-2012, 10:44 PM   #10
Rewards Points: 31
Hardwood Head is offline   Reply With Quote
Old 10-23-2012, 05:22 AM   #11
Fiber glass, rock wool and slag wool and rolls are most commonly installed in the sidewalls, attics, floors, crawl spaces, cathedral ceilings, and basements of homes.
Tony_01 is offline   Reply With Quote
Insulation question for vaulted home Talgonadia Insulation 3 08-22-2012 06:06 AM
?'s about foil-faced "bubble wrap" insulation badger73 Insulation 5 06-25-2012 05:09 AM
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 11:16 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
