Insulation Around Electricity - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-15-2008, 10:22 PM   #1
Insulation around electricity
I have an opportunity to insulate the ceiling above my home office without tearing out or poking holes in the perfectly good ceiling, because we are residing the house and there is one sheathing board that when popped off allows access to all the rows of empty space between the rafters.
So, I thought I would rent a unit from Home Depot and use blown-in cellulose.
However, i don't know what happens when you blow this stuff in and around light fixtures, of which there are several in this ceiling.
Is there a fire potential or other problem with blowing this stuff into bays that have electrical fixtures?
Thanks.
Johnfx is offline   Reply With Quote
Old 12-15-2008, 11:02 PM   #2
Registered User
Termite's Avatar
Good question.
There can be problems, depending on the light fixtures. I assume we're talking about can lights here. You need to determine what kind of cans they are. Remove the bulb and the trim kit from one of them (from living area side) and look for a sticker inside it. You're looking for "IC" stamped on that sticker. If they're IC rated cans, you can pile insulation around them. If they're not, it would be best to be safe and give them at least a few inches of clearance from the insulation, because they need to breathe.
If you're just talking about the electrical boxes to which light fixtures are mounted, there's no problem with putting insulation around them.
Old 12-17-2008, 06:57 PM   #3
Thanks, KC.
I will check for the sticker.
So, if it says IC on the sticker, blown in should be ok, even if it goes all in and around the electrical unit?
Old 12-17-2008, 07:55 PM   #4
Registered User
Termite's Avatar
Insulation can be blown in contact with the attic-exposed parts of an IC rated can light.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Old home insulation woes nowwhatnapster Building & Construction 15 11-02-2008 11:59 PM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 02:13 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
