Insulation Around Chimney - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-08-2011, 01:06 PM   #1
Insulation around chimney
May I put insulation around a chimney that runs from the furnace in the basement out through my attic? I just want to put it at the opening in the floor boards right around the chimney in the attic, so the walls where it runs through shouldn't be so cold.
cfeuer is offline   Reply With Quote
Old 02-08-2011, 01:12 PM   #2
Rewards Points: 1,092
That depends on the temp of the pipe. Check to see what your effluent gas temp is, then check w/ the pipe manufacturer/local supplier for what temp the pipe will be (assuming double wall pipe). Mineral wool may be what to use; it takes a fairly high temp and is used in your type of situation.
The Following User Says Thank You to jklingel For This Useful Post:
cfeuer (02-08-2011)
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Insulation behind brick chimney? scoutn General DIY Discussions 13 11-15-2010 05:39 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Fireplace Remodel - Insulation around chimney GeauxCajuns82 Building & Construction 3 01-19-2009 04:30 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
