Old 04-28-2010, 02:37 PM   #1
Knows everything but that
Insulation from addition to old construction
So I have an non heated/cooled crawl space above my addition. As you can imagine it gets very hot or cold up there depending on the season. The actual addition is adequately insulated into the living area. However, the part of the addition that covers the old rear of the house is not insulated. This would be the part of the upstairs of the old part of the house. They have cut and run ducting through the roof of the original house that stick into the crawl space of the addition. Its kinda hard to describe and Ill get pics up if needed. Anyway, these holes are allowing cold/hot air from the addition crawlspace into the floor joist area of the upstairs main living area. Can I simply place insulation over the holes or do I need to seal them some other way first? Also, can i just lay insulation over the old roofing as well? THanks!
Shane
JakAHearts is offline   Reply With Quote
Old 04-28-2010, 04:15 PM   #2
Xtreme DIY'r
You have a crawl space above an addition ?
Usually a crawl space is under a house.
Or is it an attic.....or a crawl space between floors ?
Pics would help
But you should be able to stuff insulation around/in the holes to stop air flow
Might even be required to fire-stop these areas depending upon setup
Old 04-28-2010, 04:57 PM   #3
Pics would help
Well, its more of an attic I guess. Its the attic above the addition. It is however, lower than the top level of the main house. Ill get pics tonight or tomorrow. Thanks Scuba
Shane
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Thoughts on this addition? sportinwla HVAC 13 04-20-2009 05:12 AM
super insulation retrofit with rigid insulation hostaking Building & Construction 5 01-07-2009 11:23 AM
insulation missing in new home construction Diyguy1223 Building & Construction 3 01-31-2008 09:51 AM
Insulation under kitchen addition rubicon789 Carpentry 11 01-26-2007 04:24 PM
