Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-18-2011, 04:54 PM   #1
insulation
what is the difference between unfaced and cellulose insulation?
anita copley is offline   Reply With Quote
Old 02-18-2011, 05:58 PM   #2
concretemasonry's Avatar
Rewards Points: 2,594
It all has to do with the concept of a "vapor barrier" in many cases. There are many forms of cellulose insulation.
concretemasonry is online now   Reply With Quote
Old 02-20-2011, 04:18 PM   #3
Rewards Points: 1,092
If you are talking about unfaced fiberglass, there is a huge difference on many levels. They are almost not the same aspect of the building envelope (ie, insulation. Yes, that is a bit of hyperbole on my part.) Fiberglass batts are terrible insulation; cellulose is very good. Read on buildingscience.com and greenbuildingadvisor.com.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 02:33 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
