Old 12-03-2010, 07:45 AM   #1
Insulation
I have a 105 year old house want to blow in some insulation in the walls. Going to use a hole saw at top of wall then blow insulation into holes. What i want to know is how to figure how much I need. Also remodeling kitchen tore down plaster and lath in there. Should i put a vapor barrier over the insulation then put the drywall up. Have heard lots of different things about the barrier.
Kurt1968 is offline   Reply With Quote
Old 12-03-2010, 01:06 PM   #2
Insulation
You'll need 2 holes in each stud bay. One to pump it in and an escape route for the air. Seal up each room as tightly as possible as insulation will blow out the top hole in each bay.
The more familiar you are with house framing, the fewer places you will miss.
To make sure you do a complete job, bring in someone to do a thermal scan of the area you did so you can fill in the holidays.
To figure what you need, just measure the room. You can always return the unopened units.
Ron
Old 12-03-2010, 03:09 PM   #3
Insulation
Ron have you done this before?
Old 12-03-2010, 03:48 PM   #4
Insulation
No. I've seen it done on jobsites I've worked. Another reason for the 2 holes is if you have a firebrake in the wall that divides the stud cavity.
Ron
Old 12-03-2010, 08:11 PM   #5
Insulation
You do need a vapor barrier in the walls on the warm side.
mrgins is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 03:33 PM
Adding insulation and storage to Cape Cod Side Attic turin39789 General Discussion 5 11-08-2010 11:50 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
