Insulation! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-28-2010, 10:30 PM   #1
Rewards Points: 978
Insulation!
Not sure if this should go in remodeling instead. So i am fairly new here and recently posted my re roofing in much detail(see my thread in roof section). now that's finally over, i am moving on to insulation.
so the old school thought is good ventilation-but i have chosen to go with the new school spray foam stuff. so my question is what do you experts think? the bid is to spray foam the decking of roof and seal it off essentially making the attic part of the conditioned space. pics to follow. has anyone else done this?? would you do it again?
thanks for all input!
federer is offline   Reply With Quote
Old 11-28-2010, 10:33 PM   #2
Rewards Points: 978
h
Old 11-28-2010, 10:34 PM   #3
Rewards Points: 978
you can sort of make out the fiberglass batt in place currently in the 2nd pic
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 02:33 PM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 10:50 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
