Old 05-20-2010, 12:11 PM   #1
Insulation
Hello,
My walls don't have insulation. Is there a method where I can spray insulation behind the drywall without having to take down all the drywall?
llckll is offline   Reply With Quote
Old 05-21-2010, 11:12 PM   #2
Insulation
... but somehow you have to generate access. Either smaller holes to have someone spray in foam, or larger ones to pump in dense-packed cellulose. You'll likely need a few to several holes per stud cavity so you can get around wires, vent pipes, etc. Call spray-in places to get details. Good luck. j
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 10:57 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
