Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-24-2010, 08:13 AM   #1
ADW
insulation
I am putting more insulation in an 1880's home. We are re-siding the house also, so is it possible to do the insulation from the outside?
ADW is offline   Reply With Quote
Old 02-24-2010, 08:36 AM   #2
ccarlisle's Avatar
If you're residing anyway, then sure it's not onyl possible but suggested. But you'll have to look into air movement barriers (like Tyvek) while doing that and then see about vapour barriers on the inside. On the other hand, if it's a choice between one and the other, spray-foaming it from the inside would be the easiest thing to do without altering the outside characteristics that much.
Don't get the cheap vinyl siding; that'll need repainting and/or replacing before you've paid for it.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 02-24-2010, 12:06 PM   #3
insulation
You should see a big difference. We did our attic and it added about 10 degrees during the winter/took off about the same in the summer.
Allison1888 is offline   Reply With Quote
Old 02-24-2010, 08:33 PM   #4
If you are going to be re-siding than definitely do the insulation from the outside. After the new insulation is sprayed in you can also add a layer of 4x8 sheets of foam from 1/2 an inch to a full inch to add some extra R-value before you side. But don't forget the housewrap water barrier. (Tyvek)
milliken23 is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 10:50 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 09:57 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
