Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-22-2007, 08:27 PM   #1
Insulation
I am building a new home and the local building codes require that I have at least R-18 in the exterior walls. What I looking for is advice on the best materials to use and also the lowest cost. Thanks for any and all help!!!
jets4343 is offline   Reply With Quote
Old 01-22-2007, 08:51 PM   #2
concretemasonry's Avatar
Rewards Points: 2,642
Insulation
Best AND lowest cost? Rarely do they happen at the same time.
If you want cheap and have wood frame, use 2x6 studs for the exterior and use fiberglass between the studs. The R19 insulation coupled with the uninsulated studs should give you an R18 or so wall if they are 16" or 24" on center. If you have 6" steel studs and fiberglass you will not meet a true R19 because of the heat loss through the steel.
Your other option for wood frame would be 2x4s, fiberglass and some sort of extruded polystyene insulation sheeting.
concretemasonry is online now   Reply With Quote
Old 01-23-2007, 06:17 AM   #3
General Contractor
joasis's Avatar
Blown cellulose is the solution, but you will have to have 6 inch walls...to get there with 4 inch walls and fiberglass, you will have to have a an inch of EPS and vapor barrier. You should be able to find a cellulose insulation installer that you can talk to. I just bought the system to add to our business...great stuff.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 01-23-2007, 05:06 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
FWIW:
THis Old House Mag. Had a small section covering the different forms/kinds of insulation. Brief descriptions, R-values, Pros and cons, etc....etc...
...If that helps you.
- Build Well -
Old 01-23-2007, 05:12 PM   #5
Thanks!
Thanks everyone for your information. After a lot of internet time, reading and a call to my local inspector I will be going with 2x6 walls and R-19 fiberglass. Its the most cost effective and will pass inspection the easiest, per the inspector. They have the last word so I guess I'll go with him. Again thanks to all! Bob
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Rigid insulation question Endeavor General DIY Discussions 2 07-17-2007 10:27 AM
dormer window insulation wlm-21 Building & Construction 2 02-13-2007 04:04 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
Insulation material reusable? KUIPORNG General DIY Discussions 4 06-19-2006 02:38 PM
