Which Insulation? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-22-2009, 08:09 AM   #1
Rewards Points: 31
which insulation?
which insulation would you prefer owens corning or john manville? Is one better than the other? I don't care about the price. I'm leaning more towards john manville since it's formaldehyde-free. Any thoughts?
kupalino is offline   Reply With Quote
Old 12-22-2009, 08:32 AM   #2
ccarlisle's Avatar
Do you think that 'formaldehyde-free' insulation is a fact - or a marketing ploy? Who do you believe anyway if someone had an opinion?
Could be the latter in what is a competitive market. Are you allergic to it? do you know about some of the other products that contain formaldehyde that you may be using right at this momnet that are of far greater concern?
I can tell you that most preservatives (e.g in cosmetics and personal care products) used daily to preserve the products we consume contain formaldehyde - either as is (it's very cheap to buy) or as a result of a chemical reaction that creates formaldehyde. I mean where you do you draw the line?
So, unless you're personally involved in the assessment of formaldehyde in your daily life, then you are left to go with your gut feeling. Do that.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 12-22-2009, 11:36 PM   #3
The higher the R-Value the better you are. You want 8" thick in ceilings.
JGibbsRemodel is offline   Reply With Quote
Old 12-23-2009, 07:10 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
Carlisle makes a good point. If formaldehyde is an issue, then forget owning upholstered furniture or any carpeting. And you can totally forget owning a car. I think the whole formaldehyde free thing is a marketing gimmick. The exposure levels are way, way below any action level. As far as 8" of insulation in a ceiling, that would depend on the location or the material. Around here it's R-38 minimum. Not any particular thickness of anything. R-38 would be equivalent to 12" of fiberglass.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 09:57 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
