Old 11-08-2009, 03:08 PM   #1
Insulation
Have a question. I have an attic that goes over the family room and garage. There is the loose insulation in the attic above the family room, but not above the garage. Would blowing insualtion in the attic above the garage make a temperature difference in the family room? I only have 4"-12" of insulation above the family room so I am thinking I need to add more to get to up to the R-49, then got thinking about the area over the garage. My gut feeling is that if I insualte the attic above the family room correctly, then it shouldn't matter what's over the garage.
Thanks,
TIm
timchi29 is offline   Reply With Quote
Old 11-08-2009, 04:53 PM   #2
Remodeling Contractor
Insulation
you are correct. Is there a wall diving the space between the garage and family room attic? There should be and it should be insulated and drywalled to prevent fire spreading too quickly.
Old 11-08-2009, 05:25 PM   #3
Insulation
there is no wall. I just went to the HD and Lowe's and found a owens fiberglass, Regal cellulose and a Greenfiber Natural insulation. Is there a type better than another? I have the cellelose currently.
Old 11-08-2009, 06:49 PM   #4
Insulation
just add some more of the same type you have now.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 10:57 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
