Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-03-2009, 05:50 PM   #1
Rewards Points: 41
insulation
Doing a DIY attic insulation job this weekend.
A couple tips I'd love to get include:
1.) I've got interior stairs in the house leading to the attic, rather than a ceiling hatch. (Makes it easy to access for storage, but harder to insulate.) The dry wall on either side of the stairs has never had any insulation on them. What's a good way to insulate these - batts?, pink board?
2.) then, I've got a chimney going thru the attic with large gaps (1.5 inches) around it. Should a chimney get air sealing around it? Do they make fire-resistant "great-stuff"? (The gap seems too wide for caulk)
Any thoughts appreciated...
kelley4180 is offline   Reply With Quote
Old 10-03-2009, 06:25 PM   #2
The insulation on the stairs will need to be covered
I'd use rolls of R15 for 2x4 wall
Then put 1/2" drywall over the insulation
My chimney is sealed, old style wall baord which is like cement
There is a great stuff that is fire resistant
http://www.greatstuff.dow.com/products/index.htm
Old 10-03-2009, 06:42 PM   #3
Rewards Points: 6,652
R-19 would be better. As for the space, I would rather have the roof & walls insulated, then have under the boards. Also, for the OP, you can look at placing a draft stop at the bottom edge of the door, and using V channels at the edge of the jamb to help stop heat loss, and drafts into the house. It is about taking a proactive approach in making for a better insulated home.
Old 10-03-2009, 06:48 PM   #4
R19 compressed in a 2x4 wall will give you R13
Old 10-03-2009, 06:54 PM   #5
Registered User
Rewards Points: 5,516
You may want to check with your local Building Department before you drywall in your attic (an unconditioned space). The door into attic should be weather-stripped with fire and smoke rated material, and possibly the door itself. Depends on local fire codes.
Be safe, Gary
Old 10-03-2009, 06:54 PM   #6
Anything is better then what they already have.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 09:57 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
