Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-07-2006, 02:42 PM   #1
Insulation
What is the best type of insulation to use? Does it depend where you live or what kind of house you're building?
cambece is offline   Reply With Quote
Old 09-07-2006, 04:42 PM   #2
Building inspector
inspects's Avatar
The department of energy has all the information you maybe looking for. http://www.ornl.gov/sci/roofs+walls/...on/ins_01.html
inspects is offline   Reply With Quote
Old 09-07-2006, 06:13 PM   #3
General Contractor
To answer your first question; everybody has their own opinion. Exterior wall I've been using a product called NU-WOOL. Check their web site. Also Old fashion fiberglass batt, is still popular.
To answer your second question; YES...
fqp25 is offline   Reply With Quote
Old 09-07-2006, 11:08 PM   #4
747
registered
747's Avatar
Rewards Points: 534
Thats a simple question. Its spray foam. Its also the most expensive. Its technical name is poly something.
747 is offline   Reply With Quote
Old 11-30-2006, 06:55 PM   #5
what is the R Value of spray in foam
Does anyone know what the cost difference between spray foam and pink insulation.
Pete
peterb is offline   Reply With Quote
Old 11-30-2006, 07:20 PM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Pete
You must be referring to ICYLENE spray foam insulation.
The prices are dependant on your area and the demand, as well as the companies who are available to do it...
Plan on spending at least double ...and up to three times the amount of fiberglass insulation.
Example: 20'x20' Sunroom addition, our company is currently constructing...(the forms go in on Monday 12/04)
These are the written estimates for insulating the ceiling, walls, and floor.
Fiberglass Insulation: $1275.00 (Our company quote)
Other Company #1 Icylene: $2530.00
Other Company #2 Icylene: $3720.00
Hope that helps.
Any company can give you a written quote if you supply the plans to them ...(Tho, they prefere to actually 'see' the job for accuracy)
Just so you know: If you insulate with Icylene in your rafter areas, you don't need to provide ventilation (No soffit venting, no rafter venting, no ridge venting = these do add up to some savings)
It is considered superior for 'air tight' insulating(walls) and 'moisture tight' insulating (Crawl spaces).
- Build Well -
Old 11-30-2006, 07:45 PM   #7
remodeling pro
[quote=peterb;25409]Does anyone know what the cost difference between spray foam and pink insulation.
Pete[/quote
Usually double or a little more. It is without doubt the best insulation as far as effectiveness, but it's hard to justify the cost if you live in a moderate climate area. Also be sure to think of everything you need to run in the walls, now or future. Fishing wires is almost impossible.
troubleseeker is offline   Reply With Quote
Old 12-01-2006, 07:52 AM   #8
How much area do you need to do or is it the whole house?
http://www.icynene.com/InsulationSystem.aspx
redline is offline   Reply With Quote
Old 12-01-2006, 10:39 AM   #9
Thanks for the reply
Thanks guys that clears up my question.
Pete
Old 12-01-2006, 01:08 PM   #10
oar
If you are building the house consider building masonry walls from AAC blocks (autoclaved airated concrete). It's concrete mixed with an ingredient that makes tiny airbubbles which accounts for the higher R value (1.25 per inch of wall thickness).
The stuff can be cut with woodworking tools and weighs only half of regular concrete blocks. You can lay up the wall yourself from small blocks or have a construction company drop in place large iron reinforced panels. panels are available to make walls, floors and roofs. The entire shell can be constructed from this and put up in 2 days.
It is a better wall tha a woodframed one. Depending on where you are you may not need additional insulation.
Manufacturers of the blocks/panels: Aercon, ACCOA, MHE, Truestone.
oar is offline   Reply With Quote
Old 12-04-2006, 03:36 PM   #11
foam
Consider an inch of foam and the rest fiberglass.
mighty anvil is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Rigid insulation question Endeavor General DIY Discussions 2 07-17-2007 10:27 AM
dormer window insulation wlm-21 Building & Construction 2 02-13-2007 04:04 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
Insulation material reusable? KUIPORNG General DIY Discussions 4 06-19-2006 02:38 PM
