Old 09-16-2005, 01:37 PM   #1
Question
Insulation
Has anyone used Cellulose insulation in new home construction. I have heard some pros and even more cons. The number one issue seems to be trapping moisture in the walls.
Rocko is offline   Reply With Quote
Old 10-08-2005, 12:16 AM   #2
2pyrs
Insulation
We used it on our addition up stairs and some of the folks around here have it in there walls. The problem is it settles as time goes by, most are complaining that the walls are cold from the window sills up. Some people here had it blown in from outside and I can’t say it looks so great having all those caps on the siding. As to my upper crawl space I have had to add more to it over the last two years. Not really cost affective in the end and not a good R value.
2pyrs
2pyrs is offline   Reply With Quote
Old 10-08-2005, 12:35 AM   #3
Insulation
will it be blown, poured, or sprayed wet?
mighty anvil is offline   Reply With Quote
Old 10-08-2005, 12:53 AM   #4
Contractor
Insulation
Foam in walls is best. Cellulose will settle.
Teetorbilt is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Rigid insulation question Endeavor General Discussion 2 07-17-2007 11:27 AM
dormer window insulation wlm-21 Building & Construction 2 02-13-2007 05:04 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
Insulation material reusable? KUIPORNG General Discussion 4 06-19-2006 03:38 PM
