Insulating Workshop Building - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-06-2012, 01:19 PM   #1
Insulating workshop building
Hi all,
I'm wondering about the best way to insulate my workshop building. It is a 16 x 20 building with 24" OC framing and a shingled gambrel roof. The siding is 19/32 PT siding. Of course there is no sheathing or wrap, just the siding nailed to the studs.
I had planned on treating the roof like an attic space, there is a ridge vent and I would add gable vents to either end and drywall across the bottom of the trusses to close in the attic space. Should I also add baffles between the rafters to prevent insulation touching the roof? There are no soffits or space to add any.
I'm also curious about whether to use any vapor barrier on the walls under the drywall.
Any advice would be appreciated!
kevrober is offline   Reply With Quote
Old 07-06-2012, 03:23 PM   #2
Rewards Points: 1,092
Originally Posted by kevrober View Post
Hi all,
I'm wondering about the best way to insulate my workshop building. It is a 16 x 20 building with 24" OC framing and a shingled gambrel roof. The siding is 19/32 PT siding. Of course there is no sheathing or wrap, just the siding nailed to the studs. Ouch. Best practice is to have sheathing, wrap, a rain screen, then siding.
I had planned on treating the roof like an attic space, there is a ridge vent and I would add gable vents to either end and drywall across the bottom of the trusses to close in the attic space. Should I also add baffles between the rafters to prevent insulation touching the roof? There are no soffits or space to add any. No soffits? Trusses don't over hang the sides? Hmmm. Ventilation is critical. There should be 1 sf/150 sf of attic floor. Baffles, absolutely.
I'm also curious about whether to use any vapor barrier on the walls under the drywall. No vb. Vapor retarder (like vr paint) and AIR seal.
See after bullets. Good luck.
Old 07-06-2012, 04:25 PM   #3
Rewards Points: 150
Are you saying that the roof meets the wall like the figure on the left?
Or is it more like the figure on the right?
goosebarry is offline   Reply With Quote
Old 07-06-2012, 04:43 PM   #4
Originally Posted by goosebarry View Post
Attachment 53612
Yeah, it's like the left diagram. This was designed to be a storage building, but given its size I want to convert it to a workshop.
Old 07-06-2012, 04:53 PM   #5
Thanks jklingel, what do you mean by "(like vr paint) and AIR seal."? Do you mean use some sort of paint or sealant between the studs to seal air gaps?
Old 07-06-2012, 06:57 PM   #6
kev: vr paint woud go on your sheet rock (i assume you'll sheet rock) and then you'd use gaskets or Tremco acoustical sealant around the sheet rock edges to air seal (as well as all penetrations, lipped elect boxes, etc). i am very concerned about that "no overhang".
Old 07-06-2012, 10:48 PM   #7
Rewards Points: 150
If he has no soffits there nothing to ventilate and no need for baffles.
Old 07-07-2012, 12:57 AM   #8
Yes, but he has SOME ventilation, and if his roof ever has a tiny leak, it is best for the roof to have a little breathing room. Besides, he may find out that he has to do some remodeling to have overhangs. PS: These Aimer ads are quite interesting.
Old 07-07-2012, 07:36 AM   #9
OK sounds good. I'm planning to go with either fiberglass or wool batts in the stud cavities, drywall, vr paint and acoustic sealant. I agree with you on using the baffles, I was under the impression that even if you don't have a soffit to draw air you still need an air gap to keep insulation away from the roof deck. I don't foresee any remodeling in the future to add soffits to this building though - with the ridge vent and adding gable vents on either end I think it will have plenty of air flow.
On the acoustic seal, is it just used along the top and bottom edges of the drywall or also on the studs? I don't know if your PS was aimed at me but what is an Aimer ad?
Old 07-07-2012, 07:56 AM   #10
WHat do you mean, siding nailed to the studs. There is OSB/plywood sheeting at least, right?
ThomasHickey is offline   Reply With Quote
Old 07-07-2012, 08:00 AM   #11
No, there isn't sheathing or wrap like I said. The siding is attached directly to the studs. This is a storage building.
Old 07-07-2012, 11:47 AM   #12
On the acoustic seal, is it just used along the top and bottom edges... yes.
I don't know if your PS was aimed at me but what is an Aimer ad? Lingerie pop up ads instead of Great Stuff, etc. Eye candy.
c after bullets. good luck. j
getting a building permit after construction is done ChrisJJ General DIY Discussions 22 08-15-2012 08:18 AM
Side Yard Setback, Height of Workshop RM575 Building & Construction 10 06-20-2012 09:25 PM
Whole house insulating help? daveo916 Insulation 3 03-23-2012 10:25 PM
Old Building problems jake62 Building & Construction 5 08-20-2010 08:32 AM
Workshop Panel Grounding/Bonding IdahoBob Electrical 3 01-29-2007 11:13 PM
