Insulating Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-28-2008, 03:39 PM   #1
Rewards Points: 1,062
Question
insulating windows
my gas bill skyrocketed because in part due to windows that are leaking air through. e.g. it is sometimes even visible by curtains waving when a stronger wind blows.
any ideas how i can temporarily fix the situation without replacing the windows ?
thx,
- a -
Old 01-28-2008, 04:45 PM   #2
thx,
- a -
Check all of the weatherstipping on the windows and replace if needed. If that doesn't work you can try something like this:
http://contractorservices.homedepot....d-748ca11de20d
I used them on my old windows before I replaced them and i seemed to work well
jerryh3 is offline   Reply With Quote
Old 01-28-2008, 04:50 PM   #3
that link did now work.
thx,
- a-
Old 01-28-2008, 05:21 PM   #4
thx,
- a-
http://www.lowes.com/lowes/lkn?actio.../9H&lpage=none
Try this one.
Old 01-28-2008, 05:23 PM   #5
Exclamation
that worked
thank you very much.
- a -
Old 01-29-2008, 12:09 AM   #6
That's a good suggestion. You might also consider insulated drapes.
We've used them before and they really make a difference.
Randell Tarin is offline   Reply With Quote
Old 01-29-2008, 01:19 AM   #7
ICF Construction
If there is trim, peel it off one window and see if the frame is insulated, if not, you know what to do on all them.
I like the insulated drapes thing too, are they actually insulated drapes or just heavy material?
Chris
Chris Johnson is offline   Reply With Quote
Old 01-29-2008, 04:49 AM   #8
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
What kind of windows are they? = sealed, vinyl?
Are they older?
Are they replacements?
- Build Well -
Old 01-29-2008, 08:36 AM   #9
they are not vinyl, they are wooden. i do not know what a sealed window is. i imagine they have been replaced at some point as the house is 100 yrs old.
thx,
- a -
Old 01-29-2008, 09:27 AM   #10
They have a foam backing. The theory is that they create an air space between the window and the back of the drape.
Although the "R" value is low, they do stop the flow of air into the living space.
Old 01-29-2008, 09:38 AM   #11
I must append the information on insulated drapes. I did a little more research and found this interesting article on the subject.
"...The use of insulated drapes can cause severe problems in very cold climates. The air trapped between the window and the drape can drop below the dew point of the air which leads to condensation on the window. This can lead to rotting of wood window frames or mold growth. If the temperature drops below freezing, the condensed water that permeates a window frame can expand and seriously damage the windows. This happened in numerous houses with insulated drapes and has lead to lawsuits between insulated drape manufacturers and homeowners. These extreme conditions happen most frequently in very cold climates..."
http://utwired.engr.utexas.edu/conse...apeDefense.cfm
Old 01-29-2008, 08:07 PM   #12
ICF Construction
Alright then...I know longer like the insulated drapes
Chris
replace anderson windows hobbyguy2002 Remodeling 13 12-06-2009 09:34 PM
Insulating basement windows Keyo77 General DIY Discussions 3 01-06-2008 06:33 PM
Insulating under extruded windows rookie50 Building & Construction 2 12-07-2006 05:54 PM
new windows juliejules4 HVAC 12 12-06-2006 01:37 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
