Insulating Water Pipes? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-03-2009, 11:54 PM   #1
Insulating water pipes?
What do I need to do to insulate pipes (water, etc.)? Any other tips for moisture prevention in an otherwise dry basement? I know I need a good dehumidifier. Anything else I need to do to the stuff above the ceiling before I add a dropped ceiling would be appreciated!
CooperChloe is offline   Reply With Quote
Old 02-04-2009, 03:54 AM   #2
Rewards Points: 5,336
They sell pipe insulation. You go to a Home Depot or Lowes and look in the plumbing section. You will need to know the size of the pipe's diameter, the metal it's made of and the length of all the pipes so you can buy enough the first time.
If you live in a cold climate, you should insulate the rim joist. That's the wood that sits on the foundation wall.
Ron
Old 02-04-2009, 07:26 AM   #3
If the basement is being finished, there is no need to insulate the pipes or ducts since it will be a heated/conditioned space anyhow. But definitely on the do list for an unfinished space. Insulating around the rim joist, any openings thru the outside wall, etc., is definitely a good suggestion.
Old 02-04-2009, 11:22 AM   #4
If you don't insulate the cold water pipes, they will sweat and drop water on the newly finished ceiling. Insulating the hot water pipes reduces heat loss which in turn saves you a little money as you will use less energy.
These pipes do not run in the conditioned space. They run above and behind walls and ceilings. But it doesn't really matter where they're run, they still need to be insulated.
Ron
Old 02-04-2009, 12:11 PM   #5
Cheapest I've found foam pipe insulation (self-sealing) is at WalMart in the States.
Reilley is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Knocking Copper Hot Water Pipes in Winter desron1964 Plumbing 5 11-19-2009 11:24 AM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
Bestion solution for insulating a 2" hot water pipe ? Wookai HVAC 14 01-15-2009 07:59 PM
Running Water makes pipes moan MikeRatliff Plumbing 2 01-25-2007 07:47 PM
