Insulating Void Between Headers - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-05-2010, 10:18 AM   #1
Insulating void between headers
This may have been a mistake....but, when I build a window header I used a 6x2 on it's flat and two 10x2 standing on their sides, however I put one 10x2 to the outside and one to the inside. Therefore there is a 2" space between them. The top is sealed off with the 6x2 top board.
So I have a void approx 2" wide 9.5" deep and 36" long.
Can I insulate this void using spray foam cans (Great stuff)?
I can drill a series of holes in the 10x2 to put the "straw" from the can through. Should I drill top and bottom? How far apart? Shoud I use the expanding foam or the minimal expanding foam?
Is there a better option?
Thanks...Paul
pshadwick is offline   Reply With Quote
Old 04-05-2010, 02:01 PM   #2
kwikfishron's Avatar
Rewards Points: 832
Expanding foam is fine don't drill your holes any bigger than the straw, less holes is better you should only need a couple. If you get to much foam in there it will just come back out the holes.
kwikfishron is online now   Reply With Quote
Old 04-06-2010, 01:35 AM   #3
Rewards Points: 1,092
Roger the foam
The foam is a good idea. Curious: What was the point of the 2x6 on its side? Convenience for something? I don't see how it was a "mistake", unless it is for structural reasons. If you put it there for more strength, next time use 2x12s instead. The load carrying capacity of a beam increases as the square of the height, so higher is always better. On its side, a 2x6 is almost useless structurally. Just an FYI; if you want to reinforce a header and don't have a ton of room (depth), add some plywood panels to the 2x10s or 12s.
Insulating furnace/utility area cbrc5eric Building & Construction 3 04-30-2010 12:03 PM
Options for insulating a concrete block house Ptron Building & Construction 7 04-05-2010 03:55 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 12:09 PM
