Insulating Vaulted Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-19-2010, 07:59 PM   #1
Rewards Points: 790
Current rafters are 2x6 24 o.c. For about 4' the ceiling will be vaulted until it flattens out. I live in Iowa and ceiling insulation says I need R-49. That would be impossible even with adding furring strips.
is there a difference in what code says is acceptable for vaulted ceilings? Or since the there will only be a few feet, is a 2x6 acceptable for insulation?
cibula11 is offline   Reply With Quote
Old 01-19-2010, 08:10 PM   #2
jlhaslip's Avatar
Rewards Points: 2,820
foam or foam board might be the answer. be sure to vent above it.
jlhaslip is online now   Reply With Quote
Old 01-19-2010, 08:12 PM   #3
Rewards Points: 790
Even with foam board (R-5 per inch) I can only can R-25. I just need to know if there is something in code that says a vaulted ceiling can be less than a standard ceiling.
Old 01-19-2010, 08:14 PM   #4
Licensed Engineer
Rewards Points: 175
High R-value foam for the vaulted area?
Ask the inspector for his/her ideas. Ultimately it will be their decision to approve or reject.
You may be able to over-insulate the flat portion of the ceiling, higher than the specified R-49, so that the overall average insulation value of the entire ceiling area meets the R-49 requirement.
R-49! Dang, that is a lot of insulation.
MI-Roger is offline   Reply With Quote
Old 01-19-2010, 08:18 PM   #5
Nope, required insulation to meet code is what is required
In some cases they may average it, but I had to meet specific insulation for walls & ceiling
Some people go to spray insulation for better results
I have R38 & may add some rigid foam board for more insulation
I use 2x12's, 2x6 just can't hold enough insulation
Old 01-19-2010, 08:18 PM   #6
Registered User
Rewards Points: 526
Don't mention the 1-2" air channel above it, may be required.
Be safe, Gary
Old 01-19-2010, 08:22 PM   #7
Rewards Points: 790
I planned on creating the airspace. I guess since the 4 ft space that will be vaulted is so small, I could sister with 2x12's and add insulation that way. I'll have to check with me inspector.
Old 01-19-2010, 09:02 PM   #8
Can super tuff r be used back to back or would it create a bunch of moisture issues? If so the dow site claims it is 6.5 R per inch plus an additional 2.8 for a 1 inch air space. Also on their site http://building.dow.com/na/en/tools/...athvaulted.htm they talk about it being installed over the rafters followed by drywall. That would gain him another 6.5. Plus if he adds a furring strip he could put in another layer of board.
Wouldn't be cheap, but I think he already mentioned foam boards.
oscarMadison is offline   Reply With Quote
Old 01-29-2010, 09:35 PM   #9
Rewards Points: 790
I had my inspector come out and he mentioned I would need R 43. I thought that was an odd number and I wonder if he misunderstood where I needed the insulation. I know we use the 2003 IRC. Anyone have info on what that particular code says about R value on a vaulted ceiling.
Old 01-29-2010, 10:12 PM   #10
Have you checked online to see if your county has a website. I've seen some counties with some pretty decent website. Maybe yours has a list of the codes for your area.
Old 01-30-2010, 04:44 PM   #11
Registered User
Rewards Points: 526
http://www.ornl.gov/sci/roofs+walls/...on/ins_16.html
Be safe, Gary
Old 01-31-2010, 08:48 AM   #12
closed cell spray foam can achieve upward of R7-R8.5/inch actually.
wnabcptrNH is offline   Reply With Quote
HELP! lighting question for vaulted ceiling pauls General DIY Discussions 5 07-03-2010 04:53 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
insulating vaulted ceiling johnnyboy Building & Construction 7 08-26-2009 10:55 PM
Running wire to a Ceiling Speaker (in vaulted ceiling) rgmetro Electrical 1 01-09-2008 10:27 AM
Vaulted Ceiling, faux wood beam, ceiling fan? zel Electrical 9 07-13-2007 05:30 PM
