Insulating/vapor Barrier A Block House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-07-2012, 08:23 AM   #1
Insulating/vapor barrier a block house
I'm renovating a 1923 American Foursquare House. Brick on outside over block with plaster right on the block. I want to 2x4 frame the ext. walls to foam board insulate, rewire and duct. This is the question. Would it be a good idea to Tyvek the plaster exterior walls as a vapor barrier? Should the vap/barr be towards the room? Thanks Tim B.
timanddusty is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
concrete block house shower medalta Building & Construction 3 11-02-2011 06:16 AM
Block Foundation w/Hundred Seep Holes? Jodust11 Building & Construction 9 04-13-2010 11:41 AM
HVAC for c. 1956 House. What would YOU do? David911 HVAC 10 02-08-2010 06:58 PM
