Insulating Under Kitchen Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-16-2008, 03:03 PM   #1
Insulating under kitchen floor
I want to insulate under my kitchen floor. It is cold in the winter because it is right in side the bilko doors in the basement. I know that i need to install insulation with the moisture barrier toward the living space but what if both sides are considered living spaces. One side is the kitchen and the other is the basement. Is there such thing as double faced insulation?
rock9575 is offline   Reply With Quote
Old 11-16-2008, 05:47 PM   #2
Rewards Points: 1,578
If the basement space is conditioned (heated or cooled), I'd use unfaced batts. If it isn't conditioned, I'd use faced with the faced side closest to the warm-in-winter side of the floor joist (facing to the bottom of the kitchen floor).
bob22 is offline   Reply With Quote
Old 11-16-2008, 08:17 PM   #3
Thank you for the fast reply. It's good to know there are people there to help when you need it. Your response makes perfect sense. It is not a condition space so i will use faced with the barrier on the kitchen floor side. Thanks again.
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
Floating Floor in the kitchen sweetwillie66 Flooring 3 02-12-2006 02:10 PM
