Insulating Under First Floor - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-29-2007, 08:15 PM   #16
Two inches of 2 lb. rigid spray foam costs about $2.00 a square foot around here.
scrapiron is offline   Reply With Quote
Old 11-29-2007, 09:08 PM   #17
digler101's Avatar
Foam Insulation
Are there applications I can purchase, or does a contractor have to come in for the foam cinder-block insulation?
digler101 is offline   Reply With Quote
Old 11-30-2007, 09:32 AM   #18
Rewards Points: 264
I don't see why you couldn't DIY the rigid board to the cinder block. Wouldn't it just take some construction adhesive?
moneymgmt is offline   Reply With Quote
Old 11-30-2007, 10:03 AM   #19
digler101's Avatar
Insulation Board
I agree, the insulated boards are a far better choice. Attaching with construction adhesive though worry's me a bit since I won't be able to go back in a year and check to see if I thwarted the water problem from the outside. Knock on wood, I have by redirecting the gutters and adding additional length to the spouts so hopefully that won't be an issue. Ahhh the joys of homeownership!
Old 11-30-2007, 10:09 AM   #20
Rewards Points: 264
theoretically, if you use foam board and seal it properly, even if mold gets between the board and the blocks it shouldn't effect the living area... yes/no? In my case, I really don't care if it does; army crawling around in my crawl space is nothing I do more than when absolutely necessary!
Ok, I guess I'm going the foam board route.
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 07:57 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 09:23 PM
Help wih floor extremer1519 Flooring 1 12-27-2005 06:33 PM
