Insulating Under Extruded Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-07-2006, 01:35 PM   #1
Insulating under extruded windows
Hi I've got two areas that are cantelevered out of two rooms about two feet by 9 feet. The floor joist are 2x12 and the underneath is just covered with vinyl siding on the outside.You can access this area from the basement where bat insulation is in place.Problem is there is air leakage entering this space and the floor above(hardwood) gets quite cold even though there is a floor register right under the window.Would removing the bat insulation and having soft foam sprayed in to fill the cavities work?This would be about twenty cu.ft of foam per window.
rookie50 is offline   Reply With Quote
Old 12-07-2006, 04:56 PM   #2
to clarify-
is there currently insulation under the extended area?
redline is offline   Reply With Quote
Old 12-07-2006, 05:54 PM   #3
Originally Posted by redline View Post
to clarify-
Yes there is some fiberglass insulation and some tar paper acting as a vapour barrier but the tar paper isn't really properly installed and the cavity is about half filled with the fiberglass insulation. You can feel the air penetration when there is any wind blowing outside.
terrible windows mt232 General DIY Discussions 10 12-28-2008 05:37 AM
Replacing "Aluminum Flared" Windows? bahaisamurai Building & Construction 6 06-07-2007 10:23 AM
new windows juliejules4 HVAC 12 12-06-2006 01:37 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
Replacing Windows shronnnda Remodeling 8 05-10-2005 12:44 PM
