Old 02-20-2008, 08:50 PM   #1
Insulating split level home crawl space.
I plan on finishing off the cooler room that was partially done by the original owner. House was built in 1975, no idea when reno was done.
its a split level home. the crawl space/ cooler room is directly below the front entrance landing.
As the pics show, there is bat insulation put in place on the walls, but not covered up. I plan on attaching vapor barrier and salvaged panelling to finish it off.
The concrete foundation part of the wall was left exposed, which to me makes sense. considering you want to keep the place cool.
My question, the "roof" of the crawl space. does that need insulation? We never noticed any coldness when we walk across the top of the carpeted landing.
2nd question. Should I put vapor barrier across the ceiling joists? Don't know if this is a good idea or not. Would it help or would it trap moisture causing rot over time? The previous owner bought it in 1996, and it has been like that for at least 11 years plus through summers/ winters.
Insulating split level home crawl space.-1.jpg   Insulating split level home crawl space.-2.jpg
sithappens is offline   Reply With Quote
Old 02-29-2008, 10:47 AM   #2
Leak Sealer
I don't know what climate zone you are in but here is a fantastic site that you must see before you do anything! http://crawlspaces.org/
IREnergy is offline   Reply With Quote
crawl space confusion shoestring General Discussion 1 07-27-2008 02:06 PM
32 inch high crawl space can a furnace fit tommar HVAC 4 02-20-2008 06:28 AM
Crawl Space - to vent or not? tomandlu Building & Construction 2 01-15-2008 08:23 PM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 09:15 PM
