Old 10-11-2009, 06:24 PM   #1
insulating sloped roof
Hi everyone. I have a new construction with two sloping roofs (6/1) that are built with 24" high trusses spaced every 24" that sit on top of some large beams that go diagonally up the walls. I have 24" of insulating space, live in Canada. I was going to run stripping over the sheathing so that I would have a cold roof (metal roofing) and then insulate the entire roof area with cellulose insulation in an closed system...no venting. The only venting is to provide air movement between the metal roofing and the sheathing. I do not have recessed lights in this ceiling either. Is that the best way? Thanks in advance for the replies.
jr67z is offline   Reply With Quote
Old 10-13-2009, 10:16 PM   #2
I would worry about condensation on the bottom of the roof deck. I would think you would need deliberate channels below the metal roof to prevent it. Scrupulous air sealing of the attic would help.
PerpetuallyRepairing is offline   Reply With Quote
Old 10-13-2009, 11:30 PM   #3
I never thought about the condensation from the underside of the metal roof, but you are right there would be a lot of it. Would the tar paper that is taped at all the seams be enough along with taped sheathing?
thanks for the reply.
Old 10-14-2009, 09:52 AM   #4
ccarlisle's Avatar
Post this in the roofing section...
ccarlisle is offline   Reply With Quote
How to design and build attic closet over sloped roof Mendosherman Building & Construction 5 07-09-2009 03:15 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing 9 02-05-2009 08:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
