Old 12-17-2010, 11:17 AM   #1
Insulating Sill Plate
Going to be insulating around the perimeter of my basement between the sill plate and the foundation. Curious which would work better here, caulking or expanding foam?
I'm using rigid foam in the rim joists with expanding foam to fill in the gaps around the sides.
Atskodinski is offline   Reply With Quote
Old 12-17-2010, 03:18 PM   #2
expanding foam will give a better seal.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 12-17-2010, 03:59 PM   #3
Thanks. Was leaning that direction but was curious to see others experience.
Old 12-17-2010, 04:16 PM   #4
I personally did spray foam on mine. I have around 70 "boxes" and wasnt about to cut foam board for each one and then try to get a caulking gun in there.
-Andrew
DIY hobbiest
Old 12-17-2010, 07:08 PM   #5
Moderator
If in a high problem insect area, use caulking as they eat or go through foam. Use rigid foam on top the plate also.
Gary
Clothes taking longer to dry?
Old 12-17-2010, 08:52 PM   #6
Gary
I plan to use rigid foam on the top plate. I'm just going to foam the small gap between the bottom plate and the top of the foundation.
Old 12-17-2010, 09:16 PM   #7
Moderator
If no sill sealer there, use either-or. Some bugs go through foam after crawling under the p.t. sill plate because the concrete sub never rodded (scrapped smooth) the top of the wall after pulling the forms.Or they "hand" troweled the wet concrete rather than using a float tool. Or the p.t. plate dried out and cupped and bowed up between the required spacing of the fasteners. The moisture will still come through as long as contact is made without a sill sealer: http://www.greenbuildingadvisor.com/...-building-code
Gary
Old 12-18-2010, 12:48 AM   #8
Gary
Thanks for link. Haven't checked it out, but will. No sealer on the sill. House built in '56. Not that well maintained either which puts me in a continuous state of DIY projects. Upon further review, I'm not even sure the gap between sill and block foundation is wide enough to make foam a good option. Think I'm just going to fill the big gaps with scraps of rigid foam and caulk the perimeter, but will use foam around the rigid foam I'm putting in the box. Understand the insect conern though.
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 09:08 PM
How short can sill plate pieces be ? tuckerz Building & Construction 2 10-04-2009 04:41 PM
rotten sill plate replacement mrad777 Carpentry 3 10-28-2008 01:19 PM
Half Lap Sill Plate Join Clutchcargo Building & Construction 3 09-05-2008 04:07 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
