Insulating A Porch Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-08-2010, 10:28 AM   #1
Solutions (handyman)
Rewards Points: 364
Insulating a Porch ceiling
The cottage porch is 8' x 16' made on 2x4 trusses, sheathing and proper roofing. I am insulating the walls (2x4 construction) and covering with 1x6 t&g panels. I also will cover the inside of the ceiling but I am not sure about insulating. Because it is 2x4, there isn't a lot of room and I know the air flow in the roof line would be obstructed. Is this an issue? Should I insulate the ceiling or leave it as is?
We are in a winter climate, but ... it is only a cottage.
Mark Harvey is offline   Reply With Quote
Old 01-08-2010, 10:44 AM   #2
Do you use the porch in the winter ?
If you heat it at all then some insulation is much better then none
Use rafter vents & R13
Then put 1-2" rigid board across the rafters for more insulation
Insulating Cold Storage below slab porch Chemist1961 Building & Construction 1 12-09-2009 08:20 AM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Screen porch ceiling archbarb General DIY Discussions 1 01-24-2009 09:15 AM
Insulating Cathedral Ceiling cholliha Roofing/Siding 3 11-25-2008 06:43 PM
